Go Back   Bristol Cars - Owners and Enthusiasts Forum > Bristol Forums > 6 cyl Bristol cars
6 cyl Bristol cars Type 400 to 406 - restoration, repair, maintenance etc
Engine Measurements
Reply
Thread Tools Search this Thread Display Modes
  #1 (permalink)
Old 19-08-08, 01:50 PM
UK6 UK6 is offline
Member
Default Engine Measurements
RE MIXTURE SENSORS
Hello Bob,
I have just ordered an Innovate LM1 in a bid to check the SU
needle which my father is running in his recently supercharged '34 Wolseley
Hornet. The anticipated delivery time is two weeks to Aust.
I think we are close with needle selection, but it would be comforting to
know that we are not running dangerously lean at wide open throttle.
Ideas to date to correlate needle position and A/F readings include a linear
potentiometer sensing piston lift (SU remember) or a graduated "stick" in
the dashpot well whereby the graduations are sensed by el cheapo tiny
security camera. If you are interested, I'll let you know how we go.
In closing, please find a reference below to very handy SU needle matching
software should you have a vehicle which would benefit from it.
Useful SU needle software www.winsu.co.uk
Brett Boughton
Ps I like the pun "leaning towards..." - very rich language Bob!
  #2 (permalink)
Old 19-08-08, 03:49 PM
Member
Brett -
Thanks much for the Innovate news! Very good to hear about the
vintage applications. I'll use the system on my Alfa (Spica fuel
injection) and Imperial (Carter carb) here to look for gross
mis-adjustments. Both cars run well, but it's a learning opportunity
for me. Then I'll send it to Barry Leitch in NZ to check the Solexs
on my FN. Barry will put it to good use for the other cars in his
shop and I'll pass along the SU tips to him
I'll likely get these items from a dealer in the area who had these
on eBay and seems to offer a modest discount. And I'll talk to them
on the phone today to make sure I'm getting the right items and accessories.
While doing this research, I came across a DIY computer-controlled FI
system which may be adaptable to any engine
http://bgsoflex.com/megasquirt.html All of this it close to the
outer edge of any application for me, but if my daily driver was a
V-8, I would be trying to learn more!
Bob
PS The pun was mere coincidence; I can only claim "rich language"
when hanging around average American hot-rodders.
  #3 (permalink)
Old 20-08-08, 07:12 AM
Member
Bob,
Another useful resource for AFR meters is at http://wbo2.com/ . I have built
a couple of their units, one is fitted in the 412 later to be interfaced to
a megasquirt unit (I`ve built a couple of these as well) which will control
a sequential gas injection system.
Useful thing with the wbO2 is that it can take inputs from other sensors,
(rpm, throttle position, etc.) and store the data. This can be read out at a
later time, so you can see exactly how your engine is performing under road
conditions.
John P
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Content Relevant URLs by vBSEO 3.6.0 PL2
