6 cyl Bristol cars Type 400 to 406 - restoration, repair, maintenance etc |
![]() I am rebuilding a 406
can someone send me some pics of the door trim / seals top and bottom the rear interior lights and this may be a silly question what's stopping me putting inertia seat belts for the from seats with the real mounted in the centre of the car by the tunnel and the connector on the outer side by the door thanks Mike |
![]() Quote:
David |
![]() Quote:
is there any chance you could send me a Pic my email is mikej.woollard@icloud.com cheers |
![]() Quote:
My mountings are a type I have not seen before. David Last edited by dwomby; 07-04-22 at 02:13 PM. |
![]() Quote:
I have now installed inertia belts front and back in the 406 so other than trying to find out what sort of seal is used on the doors I'm ready to drive once again thanks Mike |
![]() Quote:
David |
![]() I added some extra angle steel across the back of the car under the parcel shelf and then mounted the reels horizontally with the lap section bolted to the wheel arch and the catch bolted to the centre channel
hope that helps do you have and pictures of the lower door seals/ furflex please |
![]() Quote:
David |
