![]() The car failed in an embarrssing way a couple of nights ago (second time).
Previously the electric fuel pump failed (two years old). Bypassed it and it ran on the mechanical pump. Fitted a new electric pump and it ran OK. Then it stopped 'mid flight'. By passed it and primed the cars. Nothing, except the pump was working (forgot to disconnect it). Reconnected it, still nothing. Checked the plugs and they are in good condition and sparking. Took the air manifold off and sniffed the carbs and could not smell petrol. There is pressure in the supply line. What could be happening? Also, the middle carb isn't connected to the choke. It that normal? There is a hole in the linkage bar and a spring is connected to the arm but no linkage. |
![]() Sudden loss of power plus decent spark does imply fuel blockage. Old ally tanks do give off cheesy crud which can block jets and fuel lines. Petrol pumps will struggle to suck enough fuel past the blockage. Maybe that's why you have both sorts of pump? Blow the fuel line clear backwards with an airline. New ethanol fuel is said to make rubber pipes swell up inside. ( eg flexi hose to fuel pump - should we be changing these?) And double check electrics; points, coil, plug leads , and inside the distributor anyway. Good luck- such a lovely car.
![]() If there is no hint of any firing at all, then it sounds like no fuel in the float chambers, given that you have a good spark. When you primed the carbs with the lever on the mechanical pump, did the lever go "slack" as it should when the float valves shut ?
With the mechanical pump, when priming by hand, you should see the fuel level rise quickly in the glass dome until it reaches the brass gauze filter. If that doesn't happen, then: Try switching to reserve, even if you have plenty of fuel - there may be a split in the main pickup tube in the tank, above the fuel level, causing it to draw in air. If that doesn't work, then try using a tube directly from a container (with some petrol in it) to the input side of the pump, to eliminate blockages, or air leaks, in the supply line. I think there should be a choke connection on all three carbs. |
![]() Thanks for the replies.
The fuel tank is a recent stainless steel tank - no reserve. I have both fuel pumps because I was tired of lifting the bonnet and priming the carbs every time I wanted to drive the car (plus getting oily fingers)! I'm getting pressure up to the banjo feeds to the carbs (only checked the end one) |
![]() Quote:
Mike 403-1402 |
