403 bristol arm rest hinge bracket
Old 02-04-24, 01:01 PM
Default 403 bristol arm rest hinge bracket
Hi
Could any one Please post a sketch of rear arm rest brackets on bristol 403 as we are in the middle of upholstering rear seat but the hinge bracket is missing from the arm rest any help would appreciated
thanks
william
Old 04-04-24, 12:17 PM
http://www.bristolcars.info/forums/a...1&d=1712229423
Old 05-04-24, 08:53 AM
If I've selected the correct thumbnail pictures, hopefully these will help.
Old 05-04-24, 11:38 AM
Hi Mike & David
Thanks to you both this is my first post and grateful for replies
It would be great to have hole centers brief sketch of pitch of holes
thanks
william
Old 05-04-24, 02:32 PM
Sorry, my 403 is still at the trimmers so I can't get dimensions for you.
Old 11-04-24, 10:45 AM
Hi
It would be very helpful if anyone can put pitch centers to sketch but thanks for replies
regards
william
Old 19-04-24, 03:47 PM
Now I've got my 403 back from the trimmers, please find attached sketch. NOT TO SCALE. Each piece is of course x 2. Measurements are the best I can do without dismantling, bug should be close enough.
The two shorter pieces are the links between the seat back and the armrest.
The two longer pieces screw to each side of the armrest. The "Stop" sits to the rear of each of these pieces, and prevents the armrest from opening too far when it's pulled out.
Hope that helps. The finish on the pieces looks like a kind of bronze flavoured anodising. I have no idea if this was standard, or was changed depending on upholstery colour. It goes well with my light beige leather.
File Type: pdf Rear Seat Armrest pivots20240419_16145945.pdf (130.2 KB, 30 views)
Old 23-04-24, 03:36 PM
Hi Mike
thanks very much for reply very helpful are the 2 connecting arms different length ??? one is 5 1/2" centers think the other ias shorter
thanks
william
Old 30-04-24, 05:13 PM
William
We may be saying the same thing - summary:-
- I previously detailed the pair of 9 1/2" long pieces that screw either side of the armrest, and the pair of 6 1/2" pieces that form part of the mechanism.
- In my haste (I was about to go away) I missed a pair of shorter pieces that complete the mechanism. These look exactly like the 6 1/2" pieces, but are 4 1/4" long with 2 holes at 3 1/2" centres.
- note that dimensions are not wildly accurate as its impossible to get accurate dimensions without dismantling. I don't think 1/4" plus or minus will cause any problems.
- so there are 3 pairs of pieces total.
Old 01-05-24, 08:47 AM
Hi Mike
Thanks for going the extra mile
We now are very close to a working hinge Its quite simple if you have the dimensions
Will post a picture when We Finnish seat
thanks
William
