![]() On the 2 litre Bristol car which was as good as engineers could produce at
the time, there is one problem which the advent of the motorways has brought to light, that is high temperature air trapped under the bonnet. The answer to this would be to put some vent holes in the bonnet forward of the fire wall, however, this would spoil the look of the car. Since I tend to do some long high speed runs in my 401 (100B2 engine) London to Glasgow (400 miles) etc. things use to become very hot in the engine dept. To counter this I fitted an original Bristol oil cooler, not that good as it was constructed with 1/2" dia round tube so the hot oil passed down the middle of the tube, but it was original and did help but I needed to do one more thing. that was to stop the hot air passing into the engine. I managed to find at an autojumble a plastic moulding from a VW that was about a foot long tube with two oval ends which fitted the oval intake hole on the Volkes air filter perfectly. I cut this in half secured one end to the air intake with a jubilee clip fitted a length of corrugated aluminium tube to the round end which I took forward passing the radiator on the left side above the oil cooler hoses. The other half of the moulding was fitted to the tube and secured ahead of the radiator thus allowing cooler air to be drawn into the engine. This worked fine and was beneficial to the engine, however, one thing I was not expecting was that there was a drop of 5 degrees in the water temperature (85 instead of 90f) in view of this I thought it might be of interest to our friends in Australia where the temp. is slightly hotter than damp old GB. My regards, Bellerophon, Chiltern Section |
![]() Bellerophon
My 400 has a 100B2 Engine, an 80 degree Thermostat and a thermostatically controlled oil cooler of a type that I've seen on other cars. In the midst of this wonderful English Summer it runs at 80 degrees except on long steep hills when it climbs to 85 degrees and oil temperature never rises above 50 degrees. I've fitted an Overdrive which gives 75 odd at 3000 rpm and that's about as fast as you'd want to go because of the noise! Us Bentley owners are used to a trace of wind noise and little else at those speeds! Are you referring to very hot weather or are you using a higher temperature Thermostat? Ash |
![]() That seems like a big differential between water and oil temps?
![]() I don't know, it didn't surprise me because I had a DB5 that had to
be driven very fast for very long distances to get the oil hot. From I remember the readings were similar. I've had loads of teething problems after a total rebuild, but the car seems fast and free revving and what you'd expect. I think it's a good 'un! Ash |
![]() When I rebuilt my 405 some years ago, knowing that I was going to do some continental touring - in particular the Liege - Rome Rally at the height of the Italian summer, I fitted one of Brian May's thermostatically controlled oil cooling systems, and fitted the largest Kenlowe fan I could, still retaining the mechanical fan. I'm glad I did, because temperatures weren't a concern even during really high ambients. The exception was the ascent of the Stelvio pass, where a combination of a fully loaded car, high revs, and, paticularly, low forward speed rendered the oil cooler relatively ineffective and a temp of 120 plus. Water temp went up in concert to about 110 indicated - but it didn't boil. No temp problems on subsequent continental tours. Now, on motorway cruising at 70(ish) the oil temp sits at 70 -85, with water temp 80-90. But I have a rather 'hot' thermostat fitted.
Brian Kidd |
![]() it may well be that mine will get that hot when it is used similarly,
so far mine has only done about 800 miles since it's rebuilt. I suspect mine might be Brian May's oil cooler kit. I'm quite excited about the car but doing everything I can to reduce noise levels as otherwise I think long trips are going to be rather exhausting. I've had new stainless steel floor retaining bolts made and put felt sealing strips wherever panels are screwed in, I've stuck bitumastic pads to every single internal panel, I've welded up 29 unnecessary holes in the bulkhead and replaced every grommet and I've used the best Motor Wilton made with 12mm thick sound deadening felt underneath it. Most of the noise is now from the exhaust, I'm going to look for rubber isolators for the main silencer mounting too. It's a superb driving car and pulls well and I've had the front seats rebuilt to improve support and comfort, so it's ready to tour once all the little bugs are eradicated. It's very near now. Ash |
![]() Quote:
As for the Astons, I've had a DB4 and DB6 and the temp differential was approx 10 degrees when fully warmed up, which is correct. It's exactly the same for the DB5. regards, Kevin |
![]() I suppose it's because there's more water circulating round the hot
bits than there is oil and possibly because 30 or 40 miles in this particular summer doesn't get anything very hot. The gauges are all re-calibrated so probably a reasonable guide too. It's a long time ago but I do remember having to drive the Aston at considerable speed to get the oil temperature up too. It would be impossible in the UK these days. I'll keep an eye on it but I don't see a problem. Ash |
