603 Dash veneer
Old 29-11-14, 05:19 PM
Default 603 Dash veneer
My restoration is coming into its last phase at last.
New carppets made an uholstery reoaired and connlised.
I now need to get the veneered dash wood removed as the clear coat is badly cracked.
Now this is not a jobe I wish or can undertake so I got Bristol to quote me.
£4,100 plus VAT split £1,300 to remove dash, £500 for dash work and £1,300 to put back.....so the best part of £5,000 was their quote.
Now I know these are expensive cars but fee this is just plain excessive and certainly not a figure I can afford.
Now I am sure lots of you must have had your dashes done and so would appreciate knowing by whom and what sort of cost.
Thanks you in advance
Will
Old 29-11-14, 07:41 PM
Default 603 veneer
rolls bentley wood repairs are a good contact 01514270220
will get more info monday ken j
Old 29-11-14, 07:42 PM
Classical Dash - exquisite veneered automotive & aviation wood trim
Old 30-11-14, 03:52 AM
Default wooden dash
try these people
Wooden Dashboard Restoration | Chapman and Cliff | Our Price List
Old 30-11-14, 07:34 AM
£5,000 to re-veneer a dash?
You can get a whole car for that
Having done some work on my 411 dash I can say that it is incredibly fiddly and time consuming removing and replacing the instruments, labeling all the wiring and putting it back together.
However, if you're prepared to do the time consuming stuff yourself, a good cabinet maker should be able to reveneer and varnish it for you for a fraction of the price.
If you want to pay someone to do the whole lot, any decent car restorer could do it for you. There's nothing particularly complex or proprietary about it.
Old 30-11-14, 11:57 AM
Default 603 Dash
Gentlemen
Thank you for your replies and apologies for the spelling in my post...no spell check on this thing.
My problem is getting the dash out and back in is the problem due to my spinal arthritis.
Getting the veneer re-done as you point out is not an issue and there are plenty of firms who can undertake this work.
My question is does anybody have experience of someone or a company in the UK taking the dash out and putting it back in or have you all done this yourselves?
Will
Old 30-11-14, 06:09 PM
I acquired a 603 where all the dash panels and instruments had been removed for refurbishment and all the lables on the wires saying what went where faded, salvation came in the form of another incomplete badly damaged 603 with all the dash and instruments still in place, this one had seen some weather as well so not all the screws holding things in place came out easily but any good mechanic should be able to do this for you for a lot less than you have been quoted. I stripped the spares car myself and refitted the dash and instruments to the other 603, in both cases this required removal of the steering wheel, this is achived by carefully easing off the centre cover removing the screws to its retainer and the large nut retaining the steering wheel. Then the covers over the indicator and cruise control switches have to be removed and the switches themselves slackened off as you need room to gently pull forward and lower the instrument panel to remove the instruments. Prior to pulling this forward you need to release the control end of the trip recorder cable from the small panel below and to the left of the steering. The only panel I found awkward because it was a very tight fit was that immediatly above the transmission tunnel, to fit this the tunnel cover and selector surround panel I already had fitted had to come off again but the lower dash does differ in design on the 603's so you may not have that problem.
One way I found to overcome the lable issue was remove switches one at a time and reconnect to the appropriate wires, the same approach can be used on the instruments though some warning lights have to be left suspended as they slot into the lense covers in the dash panels.
The eyeball air vents are retained by long screws covered by spacers which drop out easily which is another thing I found out the hard way and the under dash covers above the foot wells have to be off to help get at everything. Very important to make certain the speedo drive cable is fully home as well otherwise it is a fiddle to get at without pulling things apart.
