Engine heat
Old 26-03-16, 05:40 PM
Default Engine heat
Hello everyone
I've recently purchased a late 1965 408, which I am delighted with, except for one small thing; it doesn't start at all well, especially when warm.
Is this a common thing and is there an easy fix? I am aware the Carter AFB carb can suffer from heat soak and fuel vapourisation.
I was considering fitting a phenolic spacer between the head and the carb. If anyone has any suggestions, I'd be very interested to hear.
Best regards
Marsh
Old 27-03-16, 12:29 AM
I would first suggest checking that you are getting adequate fuel pressure at the carburettor when this problem occurs. You need around 5 psi. You can buy an inline fuel pressure gauge quite cheaply. For better accuracy use a gauge with a range up to say 15 psi rather than one that goes up 100 psi.
Old 27-03-16, 04:21 AM
The choke on the early V8's is controlled by a spring in the manifold below the carb on the rh side of the engine, you will see a rod going down to it, it is adjustable but I cant remember how but it is in the workshop manual and Bristol cars can sort this out for you or tell you what to do to adjust the spring.
An easy check when the engine is cold is to take the air filter off , if the flap in the front of the carb is not totally closed push it shut having pumped the throttle a couple of times before and it should start straight away, if it does the spring is the problem and is fairly easily obtainable from American parts suppliers and ebay.com if it should be broken and the usual sources don't have it.
Old 27-03-16, 04:44 AM
On the hot start side the 408 and 410 I had had a metal fuel pipe coming into the engine compartment and a rubber pipe connecting this to the carb, all a bit close to the manifold so careful use of cable ties will help to keep these off the manifold.
However all the V8's I have had 408, 410, 411 and 603 benefit from a bit of throttle to catch the engine when it fires when hot, rev it until it settles down and you should have no problems.
If this does not work a new or overhauled carb might be a good idea and you will save yourself a packet and have more choice by ordering direct from the USA.
You should also be able to get a rebuild kit direct from the states as well.
Old 27-03-16, 05:35 AM
Originally Posted by Geoff Kingston View Post
An easy check when the engine is cold ...
I thought this was a hot start problem?
Unfortunately there are numerous things that can cause starting problem, but there are a couple of fundamental requirements - fuel and a spark
Marsh, what's the cranking speed like?
And when it won't start when hot, is there any combustion happening - is it almost starting or is there no sign of combustion?
Old 27-03-16, 03:08 PM
I realised it was both hence the two replies, I think you are right about the fuel pressure as well, on my 411 it was poor with the manual pump so we converted to electric and eventually a new Carb with a manual choke, now starts no problem hot or cold. On my 603E the carb was damaged so was replaced and an overhaul kit obtained to rebuild the old one at a later date.
The engine still had the block mounted pump but the previous owner had fitted an extra small electric pump to aid starting. We replaced the lot with an electric Facet pump with an in line fuel pressure regulator and have had no problems since.
Hot starting was a issue I suffered on an R Type Bentley we found that the spark was too weak to ignite the fuel when the engine had stood for a few minutes, having gone through everything with little improvement on the standard set up, the general forum advice was to fit electronic ignition.
The system I chose was Fred Winterburn's capacitor discharge unit which cured the problem completely and made the engine run a lot better on modern fuel.
Edlebrock do heat insulating spacers for various manifold and carb set ups and according to some postings on a Chevrolet forum have cured the hot start issue for some owners.
Last edited by Geoff Kingston; 27-03-16 at 03:39 PM. Reason: Additional information.
Old 27-03-16, 04:31 PM
Thank you gentlemen - that gives me some food for thought!
When the car is hot, I'm getting pretty much nothing; certainly little signs of combustion - the starter is churning away merrily with no discernible firing and only after very aggressive pumping of the accelerator will it finally catch. In terms of cranking speed, my gut instinct is that the battery may not be long for this world - it's kept on a conditioner and appears to be ok, but from past experience of V8's, It would be better to be sure and invest in a new one.
I've only had the car for a month or so and am now getting used to it; it is due to go over to my mechanic in the coming weeks for a full check over and he's going to take a proper look - I'll obviously keep you posted on progress.
I've yet to join the BOC, but just for reference, my car is a 408 Mk 2, chassis number 408/7214 which I'm given to understand is the penultimate one made. It now carries the registration number VEW408, but was originally KPG675C. It was fully restored between 1997 and the early noughties by previous owner David Rowlinson and remains in lovely condition.
Best regards
Lee Marshall, aka Marsh
