Centrifugal Ignition Advance
Old 14-12-22, 03:02 PM
Default Centrifugal Ignition Advance
Hi All
The Vacuum advance unit on the distributor of my 410 has failed. I have taken the distributor to Holdens and they are going to rebuild the vacuum unit. Whilst there, they will also check the distributor over and replace any worn parts and test the mechanical advance. Does anyone know what the correct figures for the mechanical advance should be please?
Old 16-12-22, 05:28 PM
You are probably too far in for it to be helpful but it may be worth just getting them to fix the vacuum unit and then order a new electronic unit. Summit Racing in the States seems to have several options:
https://www.summitracing.com/search/part
type/distributors/make/chrysler/engine-size/5-2l-318
I have read that distributor in the A series Poly 318 as fitted to the Bristol is interchangeable with that from the later LA. That said, I'm not an expert. It's just a suggestion to speed up your research. Best of luck and please report back.
Old 18-12-22, 06:34 PM
I am in full agreement with David, I fitted a Mopar Electric Conversion Distributor to my 410 nearly 4 years ago. I was having a few issues with my existing distributor and rather than having the existing unit repaired/overhauled, I decided to buy the Mopar unit. It was a very straightforward fit.
I wouldn’t consider going back to the old distributor but whoever becomes the next owner of my car, they will have the opportunity to have it overhauled, if they want originality, as it’s there in the parts box for posterity, gathering dust, along with the original Carter carburettor which I have had refurbished and set up for performance, as opposed to my Edelbrock, currently fitted, which has been set up for economy.
Old 18-12-22, 10:42 PM
Default Distributors
Thanks for that. Did you need to make any modifications to the tachometer circuit please?
Old 19-12-22, 12:19 AM
I have found some useful info online about the issue of electronic ignition upgrades causing the tacho to fail or become wildly inaccurate. It seems the tacho needs to be converted from RVI type (coil on rear or bullet connectors with coil inside) to RVC. There is a DIY fix using a circuit board that has to be fitted inside the tacho. I found one on Ebay, item number 380578001095. I haven't tried it yet but plan to soon.
Old 19-12-22, 04:35 PM
Yes, I sent it to a company to have it reconfigured. Sorry for the late response.
