lucas dcb 121c condenser
Old 16-05-10, 09:15 PM
Default lucas dcb 121c condenser
Hello, in my ac ace I have a 85c engine,
Ihave problems with the condenser the points are burned(pitted)
I now mounted a condenser which is normaly used in a Triumph TR3A
It works oke.
Can this give any problems?
Old 16-05-10, 10:18 PM
Default Condenser
No, the condenser is just there to prevent arcing; it won't give you any trouble.
Old 17-05-10, 08:26 PM
Thanks for your quick reply
Cornelius
Old 22-07-10, 10:57 PM
Cornelius,
I'm not a Auto Electrician but know the condenser vary in capacity .
I cant find the values of 6 cylinder Bristol condensers (Lucas part
#407044) or TR3 (423871) but looking at values of other cars condenser it
can vary between 0.18 - 0.32 MFDS .
It is probably dependant on coil & points used.
Most likely the TR condenser will be suitable but if not it will probably
quickly burn/pit the points.
Surely you can go to a spare parts shop and buy the correct one , they are
readily available in Australia.
Old 22-07-10, 11:05 PM
Cornelius,
