400 direction indicator switch mechanism
Old 06-01-14, 09:44 AM
Hi Marcus
If you are not concerned about the self cancelling (timer) the switch can be replaced with a simple manual indicator
Holden Vintage have such a switch (part number 020.071 - manual indicator switch) it's a repro Lucas Item I think.
you will need to use your existing indicator lever, the extension shaft and the joints - these attach to the new switch shaft after you have removed the supplied indicator lever.
changeover is straightforward if somewhat fiddly - you will need to remove the existing switch by removing the binacle from the engine side.
PM me if you need more details
cheers
Julian
Old 09-01-14, 11:08 AM
Thank you Julian and your suggestion and advice my be the best option as I currently have the original 'tired' mechanism in bits on the bench and at least I now have the option of a positive 'on/off' switch as a long stop.
Many thanks
M
