401 Petrol Tank Sender Unit
Old 21-07-14, 10:06 AM
Default 401 Petrol Tank Sender Unit
Hi,
I can't find my workshop manual at the moment and I'm not fit enough to get underneath.
Exactly where is the sender unit on a 401 petrol tank please. No guesses just a knowledgeable answer if poss.
Bob W
Old 21-07-14, 10:15 AM
Default tank sender 401
Tis on top.
Old 21-07-14, 01:02 PM
Default Thanks
I feared as much!!!!
Old 21-07-14, 05:22 PM
Access through the boot though !
Old 22-07-14, 09:41 AM
The sender unit sits on top of the tank. There is a cover in the boot at the back held by two screws and the unit is below on the right.
Take careful note of where the float goes in the tank as it will be fouled by the baffles if not fitted correctly.
Old 25-07-14, 06:13 AM
Thanks Lads, that's a relief, I thought I might have to drop the tank. I must find my Workshop Manual!
Old 25-07-14, 08:47 AM
Maybe this helps
Old 06-08-14, 02:58 PM
As I will have to drop my fuel tank how are the staps fixed and are they easily accessed from below (not having any lifting facilities beyond wheel jack and axel stands)?
'Top side' isn't a problem.
