401 Exhaust System
Old 17-08-15, 06:50 AM
Default 401 Exhaust System
Can anyone suggest a supplier for an exhaust system for the above car - either in the UK or Europe
Old 17-08-15, 08:35 AM
Default 401 exhaust
1. Bristol Cars will almost certainly be able to supply.
2. For stainless steel systems I can thoroughly recommend JP Exhausts of Macclesfield. They will have the pattern to work from or by prior appointment they will make and fit a system to your car in a day. Turn up at 8.30 am and drive away late afternoon. They supply a lot to the trade but will also deal direct with owners.
Chris.
Old 17-08-15, 09:39 AM
Default Stainless exhausts
If you aren't able to get to Bristol cars, Longlife exhausts will make you a custom built stainless exhaust with a lifetime guarantee. They have various branches - the one near Bristol did a good job on my 400. You can specify a larger diameter tailpipe, maybe a good idea if your engine output has been raised.
