400 radiator pressure cap
Old 26-02-24, 10:37 AM
https://liquidintelligence.com.au/pr...diator-coolant
Michael,
the Marston Excelsior unit has a spring loaded ball which passes steam and more importantly, prevents the ingestion of air as the radiator cools. In the absence of this valve the tip of your overflow pipe needs to be submerged to reduce coolant loss and to prevent air pocketing.
The original low/no pressure radiator does an adequate job of cooling in hot, humid Queensland.
The soluble oil coolant product is touted to boil at 115 degrees centigrade at one atmosphere.
sincerely,
vincent.
Old 26-02-24, 12:02 PM
Thank you both. I was not aware of the original system that my 401 had and as my 400 has the ali rad and more modern cap I was curious. Always better to understand these things. The cooling sustem is working fine so apart from checking that the overflow pipe sits in liquid I will leave well alone.
regards
Michael
