Lucas Windtone
Old 07-04-10, 08:50 AM
Default Lucas Windtone
An odd but simple question. Where are the horns located on a 400? Mine appear to be missing........
Old 07-04-10, 10:13 AM
Clifford ,
they are attached to a angle iron bracket which is bolted to the steering
rack securing bolts . I can send you a photo if required ,
Old 07-04-10, 12:45 PM
Ex Member
On mIne they are in the center in front of the main spring. Basically some
8" behind the front number plate.
Others may vary and in some 60 + years....
Dorien
Old 07-04-10, 01:50 PM
Dorien ,
yes you are correct but check where& what they are attached to !!!!!!!!
Old 08-04-10, 11:14 AM
Thanks for that. Sure enough I have a bracket with holes in it...
