Bristol 401 - engine 85C
Old 16-08-12, 01:35 PM
epw epw is offline
Default Bristol 401 - engine 85C
Cylinder head spanner ring- part # 600161 .Does anyone know of an equivalent tool that will " do the job"?
Old 18-08-12, 10:31 PM
You could try a 1/4" whitworth ratchet spanner -king dick available on ebay.
KING DICK RATCHET COMBI SPANNER 1/4" WHITWORTH | eBay
Its 72 clicks so every 5 degrees it gets a bite.
I would like one of the correct spanners myself. I think they are termed an obstruction spanner.
FH
Old 21-08-12, 12:52 AM
epw epw is offline
Smile engine 85C -cylinder head spanner ring
Thanks for the information.I will follow-up
Old 30-08-12, 04:49 PM
Hi, I loaned my Bristol Spanner out quite some years ago and never got it back, so I'm looking around.
Snap-on have "S" shaped spanners/wrenches in imperial AF sizes. IF the cylinder head nuts are 3/8" Whitworth then I beleive it would apparently be 1/2" AF?
Snap-on SBX 1416 is 1/2" and 7/16". The cost including post and vat is £42.66 and I have just been quoted this. They are out of stock in the UK at the moment but I aim to try one if I can get the cylinder head nut size confirmed.
I've only ever seen one for sale on EBAY and this went for about £100 or so. I can go back to the time a cylinder head complete with running gear was £89.50. I wish I had a shed full !!!!!!!
Bob W
Old 19-09-12, 06:54 PM
epw epw is offline
Bob W
Thanks for the info./comments.The size is 1/4 " Whitworth.Still looking.
Old 19-09-12, 06:57 PM
epw epw is offline
Removal was done with a very short 1/4" Whitworth but this will not be satisfactory for installation.
Still looking.
Old 14-10-12, 10:39 AM
I bought one of the ratchet spanners (earlier in thread) and it fits nicely on all the nuts on the inlet manifold side except the front and rear one.
It needs ground down further to fit the front and rear one. I have not done that yet but dont think its an issue.
Graham
Old 02-11-12, 10:50 AM
Default Replica Spanner
I Have Just Made My Own Spanner
Obtained Tracing Off An Original Spanner
Purchased 2 * Whitworth Ring Spanners
Bent One To The Correct Shape Then "Cut And Shut" The Ring Off The Second Spanner .
A Bit Of Welding Heating And Grinding For A Good Result
