401 ignition switch lucas 5 replacement
Old 30-04-13, 07:36 AM
Default 401 ignition switch lucas 5 replacement
I am having problems with my ignition/lighting switch. I looked at the lucas plc5 aftermarket offerings but they are different from the bristol parts manual (manual quotes the lucas plc5) pics. Has anyone had to replace a 401 switch and if so how did they manage it. Any thoughts out there. Mike Say
Old 30-04-13, 08:05 AM
Hi, my Lucas parts list shows the switch as PLC6 Part No. 34051. Mine is a bit loose and needs tightening but I'm afraid I've never had to replace one.
Bob W
Old 11-06-13, 07:30 PM
Default Faulty switch?
First of all: I have seen some of these switches at Beaulieu. Also, I had problems with my switch, as it was expected to do more than it could, as in run more than 10amps through it! I connected it's output straight to the coil, but only one other connection, to a relay to control the power of anything else I would want 'on' when the ignition was 'on'.
