409 wheel bearings
Old 17-07-13, 09:15 AM
Default 409 wheel bearings
Does anyone happen to have the bearing manufacturers references for front inner and outer wheel bearings on a 409 please?
No doubt they'll be marked on the old ones, but I would like to get the new items before I pull the hub down. Even better if there's a seal reference.
Mike O
Old 17-07-13, 04:08 PM
Banned
Default New bearings for the 409's and most everything else
Most all commercially available bearings are marked with identifying numbers; usually 4 or 5 digits. There are also reference books at bearing sellers that contain most all applications that we can imagine. If that fails, simply take your old bearings with you, and you will be amazed how quickly you will have the new ones in your hands.
Old 18-07-13, 10:50 PM
Default 409 bearing refs
Thanks,
I hav enow removed the hub and outer bearings have references familiar to me from other vehicles. As soon as I can get the inner ones out and seal numbered, I will post them on the thread for possible assisatance of others
Old 25-07-13, 07:56 AM
Default Bearing part numbers
I have now obtained and fitted the front wheel bearings and seals. In case it helps someone else at a later date. here are the refs;
Oil seal National 3946
Outer bearing LM11910-LM 11949
Inner LM 48548-LM48510.
